Odd oil pressure issue - B235r
1497 Views 74 Replies 14 Participants Last post by  leifr
hey all,
I have an '02 Viggen convertible with 76kmi. It has been in the family since new and strictly maintained. Over the years it has had a number of oil leaks, most of which have been resolved (crankshaft seal, oil pressure switch). One that remains is the head gasket - and I know I need to bite the bullet and have it replaced. It drips maybe a half teaspoon a week onto a pan on my garage floor. The car is driven about 20-50mi a week. Oil level is checked frequently. No engine modifications.
When the car is driven more than about 20-30mins, the oil pressure light and red triangle start illuminating at idle (e.g. at a light or in traffic). This only happens at idle - a slight blip of the throttle makes the lights go out.
When this first started happening (about a month ago), I took it immediately to my trusted Saab mechanic. They pulled the oil pan to check for sludge - none was found. Everything is clean. #4 piston bearing was checked and is good. They replaced the oil pressure switch again, thinking it could be a faulty sensor. But the problem remains. Otherwise it runs & drives perfectly.
Since this only happens once the engine is fully warmed up & driving for 20-30mins, is it possible that the head gasket issue, combined with the expanded metal of a warm engine, is contributing to low pressure at idle? Has anyone seen a problem like this and could suggest potential causes?
Thanks!
Randy
1 - 20 of 75 Posts
When i inspected the bearings on my 2002 t7 engine, all bearings looked good except the center main crank bearing was down to copper. Engine had 220k mi on it though. I would suggest getting an actual pressure guage hooked up so you know exactly what the pressures are
  • Like
Reactions: 2
I would not suspect the cylinder head gasket for your oil leak, as long as the engine works properly. A faulty headgasket would give you a lot more trouble, like rough idling, loss of water, overheating, exhaust blue/white smoke and lack of power.
The oil leak might also come from the cylinder head cover.
When your oil pressure warning light goes out by a slight blip of the throttle, there is probably no majore failure, but i will recomend Saaberachis recommondation.
  • Like
Reactions: 1
What describes a SAAB T7 engine compared to a B204i ?
Oil will take a long time to get fully hot--considerably longer than the coolant So it sounds like you aren't getting enough oil pressure at hot idle.
What oil are you using? Mobil 0W-40 is on the thinner side of the spec.
I would back this - definitely get an actual oil pressure gauge on there to see what's up.
It would take a prodigious leak to affect oil pressure... what's described here is reasonably typical of these motors.
If the car hasn't been driven much, there could be wear. Could also be a gummed up bypass valve, or dried o-rings on the oil pickup or crossover tube. Did they replace those when they dropped the pan? Did they remove the pickup strainer to be sure it's not clogged up?
  • Like
Reactions: 2
T7 is b205/235. B204 is t5 if turbo'd & motronic if n/a i believe
  • Like
Reactions: 1
B234 came with Motronic in the NG900 but Trionic in 9000.
Was the motronic n/a & the turbos t5?
Theres a 95 900 vert in the yard with a 234i. I grabbed the distributor, coil & intake cam just in case
No, all four cylinder 9000s used Trionic regardless of aspiration.
Even V6 9000 uses Trionic5.
  • Like
Reactions: 1
I always thought trionic-tri=3, was turbo cars only. Fuel, ignition & boost .
That's the idea, but the CS 9000 only ever ran Trionic.
  • Like
Reactions: 1
Nope. 1992 B202i and B202S ran with LH Jetronic and DI/APC.
This is helpful thanks! I believe they checked all the o-rings & bypass valve when they had the pan down, but will double check. Pickup strainer was clean. Such a mystery!
I’ve got the pan off on my 9-5 Aero. Should I check the bearings while I have it off? It’s only got 120,000 miles on it.
If you have a good torque/angle wrench i would. If you had good pressure & no knocks or lower end issues, with that milage it probably wouldnt be necessary. But while you're in there. If you decide to, i'd check the middle main & #4 rod bearing for sure
  • Like
Reactions: 1
Checked the middle main. Seems like it's in good shape, but this is my first time pulling one of these apart so I snapped some photos.
Thoughts? What am I looking at here? Seem like it's okay?
Wood Denim Artifact Fashion accessory Art
Wood Gas Door Tool Hardwood
Wood Gas Engineering Machine Cable
See less See more
3
Ya it looks ok. When its worn down past the grey lining into the copper colored lining, its definately time to change them because the next layer will wreek havok! Lol
  • Like
Reactions: 2
1 - 20 of 75 Posts
