I've done weeks and weeks of research about the battery drain issue but can't seem to figure out mine. I have a 2004 Saab 93 and have run into the battery drain issue. I used an amp tester on the battery and have noticed about a 1.5a constant drain with the car off. I hooked it up to the # F30 Maxi fuse and noticed the 1.5 coming from that fuse. I then went into the fuse panel inside the car and began testing each fuse. There was about 4 different fuses that were drawing from anywhere .1-.3a each. Does anyone think maybe my car is not powering down all the way?
