I'm a car guy but have never had dealings with any Saab. Then a friend asked me to help her move an 84 900 out of a storage lot. it has been sitting for well over a decade so I'm not trying to start it, but I can't get it to roll so i can load it on a trailer. I was convinced it was a problem with the ignition because if i crank it in gear it lurches, but if i push in the clutch or put the trans in neutral, it cranks normally (I removed the fuel pump relay before it tried to crank it to keep any sludge from running through the fuel system).
I could tell the key was not engaging properly because it didn't click through the detents (i hot wired the switch to get it to crank). I cut up a socket to get the goofy nuts off of the ignition/shifter assembly, then took the whole thing apart. The switch appeared to working correctly and i could click it through the detents and get it to crank, but still can't figure out how to get the trans in neutral so it will roll. I even tried wedging a length of pipe on the seat to hold the clutch pedal down, but no luck.
Is there some sort of an interlock that will allow the trans to disengage so the car will roll freely?
I'm pulling out what little hair i have left, so I appreciate any advice you can give me!
