Since having the valve problems my car has been making a ticking noise at certain engine speeds (about 1100rpm).
I thought it was my alternator (which needs new bearings) but had a proper listen today and it sounds much more like it is the waterpump. You can even feel the noise through the water pump cover.
It is not leaking and is working perfectly so i was wondering how it is causing this noise? is it likely the bearing has gone in the pump? (it is about 3 years and 30k miles old now) or could the impeller perhaps have moved slightly so that it is hitting the cover plate?
I am assuming that it started happening since the valve problems because as i drove the car with the dodgy valve it was putting resistance/tension back on different bits of the engine through the timing chain due to having no compression on one cylinder and thus having to 'pull' that piston down rather than it being pushed.
