Ok, well when Jim and Peva both say not to run Seafoam I think its a good idea NOT to run seafoam
so that got returned and decided just to put some fresh oil in there.
The oil was on the low side of the marker (and I knew this beforehand) - I suspect she is burning a bit of it with the engine having north of 258K (odometer is broken) I had intentionally filled last time on the low side, as I had a seal go out on my first 900 when a garage had slightly overfilled the oil by about a quart.
Anyways, switched from the M1 5W-30 that was in there to M1 0W-40 and made sure to fill it further than last time.
..The engine is a lot quieter...maybe being an old engine the low oil level combined with less pressure to begin with, was causing lifter noise. We will see tomorrow as the noise is the worst in the cold mornings on a cold start.
