1 - 2 of 2 Posts
After a couple of enjoyable weeks of driving the vert after my complete front end rebuild...I knew somthing had gone wrong.:eek:
I kept hearing a clunk up front, and some serious wobble in the front end. I check out the suspension...everything was tight....then I found this.....a bolt had broken off my brand new motor mount....so I guess the right side of the engine had been slopping around....
I just realized...that bolt was already there....duhhh;oops:...guess I'l have to drill it out....anyway..the bentley is unclear as to the correct torque on the motor mount bolts....any suggestions?
Discussion Starter · #2 ·
Is that bolt threaded into it's mounting sleeve?.....it looks like it should just punch out....but...I can't get it to turn from underneath...already starting to round off... and I can't get a good angle in to drill it out
1 - 2 of 2 Posts
