1 - 2 of 2 Posts
ok - found a couple threads on the "DICE" and the "buzzing" below the dash I need to comment on.
On the way to work this morning, my car did the same. Buzzing under the dash, no windows - no signals. Wich, REALLY sucks considering you can't use hand signals .... so, what I found ...
When it first happened, kicking the "kick" panel - fixed it. . . . till I kicked a wire loose. (thin black one)
From the center relay (pretty thick purple & red wires going to).
Apparently, this relay controls all of the above functions
.. oh, and unless you like a tattoo of a minus sign on your thumb and first-digit, don't try to hook this onto a LIVE (red or purple) wire - it's not fused.
Taking the whole assembly apart is only one screw and a wire-cutter around the batch of wires.
I found out where it came from - and voila - everything works ... plus, a little black-tape on the melted wire.
+, I gotta Saab tattoo now =)
Discussion Starter · #2 ·
OH - I suspect, that the loose Black wire was causing the relay to "buzz".
1 - 2 of 2 Posts
