I am a fairly new owner of a 1997 Saab 9000 Aero, which has been giving me trouble with the brake, tail, and dash lights.
When I bought the car, the owner said that the "brake light out" indicator on the dash would not turn off, but that all of the rear lights were functional. A couple weeks later, the right brake light failed and I went to Kragen to pick up some replacements. I was in a hurry so I had them bring up the bulbs on the computer and grab them for me...didn't put them in the same day.
One night I turned on the car and noticed that the dash gauges and climate control console failed to back light. I don't drive at night often, but always drive with the headlights on, so they may have been broken for quite some time. That same evening, I got pulled over and given a fix-it ticket for my brake light that I had yet to fix.
A couple days later, I put in a new rheostat having read that it could be the point of failure for the dash lights...still no lights. I then replaced the brake bulb and it seemed to work fine. However, that evening I kept messing with the rheostat while I was driving and noticed that the dash lights came back on! A miracle...or so I thought.
I pulled into a gas station to clean my windshield and the car wouldn't turn off! I could pull the key right out of the ignition and it would still be running. In the process of getting the car back home, I also noticed that my dash lights would now ONLY light up when I hit the brake pedal.
Some forum detective work let me know that I had the wrong bulb in the brake light socket...single filament rather than the double filament it is wired for. I put the OLD, apparently dead bulb that got me a ticket back it and it seemed to light up just fine, and the car turned off each time I drove it that day.
But NOW, the taillights do not light up when the headlights are turned on, and the dash lights are back to being completely dark. Turn signals, flashers and brake lights all work. But this thing is completely unsafe to drive at night!
I noted that the instrument cluster, rheostat, and brake lights are all on a single fuse. While the taillights are on another. Because the double filament bulb serves as a taillight AND a brake light (when it gets brighter) I think that my single filament bulb jumped the contacts and burned out a relay or switch associated with the taillights.
All of my fuses check out, rheostat worked for the short time that the dash lights were lit up, all the bulbs are good, and the circuit board looks clean.
What do I look at next?! Is there a taillight relay that I can inspect? Could it be something fried at the dash switch for the lights?
