Hello all,
First off, many thanks to all the posts on this forum that have helped immensely with troubleshooting, but I seemed to be stumped.
My 1987 Saab 900 Turbo started stalling on the way into work last week. The stall occurred with a pulsing like behavior, somewhat stalling worse under load. I popped the hood while running on the shoulder and wiggled the connector at the distributor (hall sensor plug) and the car died. I could clearly see heavy oxidation on the ground wire. After doing a road side repair (twisting wires) I was able to get the car back home, but it ran poorly.
For the repair I cut back the wire loom, removed the wires from the plastic connector and repaired the three wires (12V-green, Ground-black, and hall signal- brown).
Since the repair I now have no spark (which on this engine means no fuel either). I am currently working through the Bentley ignition troubleshooting and have hit a snag. With the ignition on(but not cranking) and the hall sensor unplugged I am getting ground on the black, 12V on the green, and surprisingly 6V on the brown. My understanding is the brown wire should only have voltage when cranking. SO, I figured there was a problem with that wire or the ignition module.
Any insights? Thanks
