1999 Saab 9-5 stopped running. No spark on DIC when running test. CPS is good, 45PSI at fuel rail. All fuses checked and ok. Oh by the way, tried 2 DIC for spark. What next?
Any recent misadventures with the twice, or ecu? reflash tune or any key changes? How do you know CPS is good just to clearify *not to question your reasoning here* have u checked to make sure not in limp mode? Just trying to cover bases here. If you pull the ecu fuse I think 17 let it stay out for about a minute and then replace it? can u get it to sputter to life then stall?
CPS is new. Checked fuses but did not keep #17 out for a minute or so. Will try that. Don't know if car went into limp mode. Just died doing 60mph on the freeway and would never restart. Had 2 DIC and could not get either to spark. Thank you for your consideration. Have a great day.
