just wondering if this is something weird with my car or if it covers all 1999 9-3s with the hot t25
i can consistantly boost to 17 psi and holding it with the mbc im using
No problem.
how high is too high to boost it?
The best way to determine that is with a egt and wide-band a/f kit. If you reach 1600f in the combustion chamber, you are at the temp where you can colapse the top piston ring...
John
The HOT alllows overboosting to 17Psi. You can't go over that or it'll fuel-cut.
assuming you have the means to get the air in and out of the motor efficiently, and have a clean-running motor/injectors/fuel-pump, you're perfectly fine.
