Hi, i have a 2001 9-5 aero. Recently i took the NSS out to clean it as they tend too gunk up. After putting it back in it clearly wasn't outputting signal, as i couldn't see which gear is was in the instrument panel. Eventually the bulbs lighting the gears themselves in the gauges also went dark. I got a transmission light as well as a tcs light. Car is also in limp mode.
Figured i must have messed up the NSS, bought a working one, same issue. Connected tech2 and the problem seems to be "no communication with TCM". Does the TCM have a fuse i could have blow with the broken NSS or could I have blown the TCM itself?
I doubt it's a wiring problem as all was fine before removing the NSS. Lesson learned, if it ain't broke, don't fix it.
Have you double checked all fuses in dash fuse box?
Check fuses with a multi meter or so. Visual check is NOT reliable.
It seems early TCM's seem to break. So you might have a problem there.
What is a NSS??
Send from my Palm Tungsten T5
What is a NSS??
I will check, but i can't find a fuse related to the TCM, unless it's the one for the automatic transmission. Will check with a multimeter, but it looked fine. NSS - Neutral safety switch, sits on top of the gearbox and reads which gear you are in.
