05 9-3 Linear in Michigan USA
For the last 4-5 years we've had to re-charge w/ R-134a refrigerant every summer due to a slow leak somewhere. This year something has changed. When connecting to the low pressure line to re-charge the gauge reads high at around 75psi. So I discharged the low side from 75 to around 5psi and re-connected the R-134a. This time it accepted the refrigerant (rather quickly), and I stopped around 40psi. AC system still blowing hot air though and when I checked the low pressure line it had climbed back up to 60psi.
It probably goes without saying but I'm not that familiar w/ AC systems.
I did check fuses and swapping relays but the AC unit seems to be running so I'm not really sure what I'm looking for (other than cold air!).
Anything else I should check/try?
Thanks for reading-
Thanks for reading-
