2003 SAAB 9-5 Aero wagon here. Brake system has TCS/ECS
So I just replaced my brake booster/servo and all vacuum lines - including the hard plastic line/assembly with the check valves between the brake booster, throttle body, and vacuum pump - and now I have no power brakes! There's no air in the lines; the brake system has been properly bled per the WIS procedure, and there's no play or sponginess in the brake pedal. I'm simply not getting any power assist whatsoever while braking.
Any suggestions on what I should to do troubleshoot this issue? I don't think I quite know how to properly "listen" to the brake booster to diagnose it (indeed, the reason I replaced the brake booster was because my mechanic diagnosed it for me, and then I opted to do the work myself without confirming his diagnosis).
Thanks!
Thanks!
