Hey guys, my 94 900S 185Hp Turbo needs a turbo. My T25 is starting to leak oil in my intake. So I want to swap it with a T4 instead so i can go stage 3 ECU safely.
I need your help guys, I found tons on ebay forsale and they are not too bad in price. Should i get a T3/T4 hybrid?
What should I look for in terms of easy bolt on, oil lines, ETC?
Also before I go Stage 3 ECU, will i be able to use my stock ecu on the new turbo without losing too much? I figure spool up will be slower due to the larger size turbo.
Your info is greatly appreciated.
Thanx.
Thanx.
