1 - 7 of 7 Posts
Ng900/9-3 Frequently Asked Questions (faq)
Thinking about buying a 900/9-3??
LINK 1
LINK 2
LINK 3
NG900 Buyer's Guide
900/9-3 Features Section (reviews, brochures)
SC Listings
What are the differences between the 900 and the 9-3?
LINK 1
LINK 2
What is a VIGGEN?
LINK 1
"Anybody know a good mechanic in Xyz City?"
DATABASE
Creaking front end in low temps
LINK 1
My car tells me it's "TIME FOR SERVICE"
LINK 1
Is there anything I can do to fix missing pixels in my System Info Display (SID)?
LINK 1
LINK 2
LINK 3
Is there a Chiltons or a Haynes for the 900/9-3?
LINK 1
LINK 2
Can I use an MP3 player through my factory Headunit somehow?
LINK 1
LINK 2
Why can't I turn my headlights off? This switch does nothing!
LINK 1
LINK 2
What kind of spark plugs does my 900/9-3 use?
LINK 1
LINK 2
LINK 3
LINK 4
Alternator replacement help.
LINK 1
Cabin Air Filter Replacement
LINK 1
CEL indicates bad 02 (Lambda) Sensor.
LINK 1
Can I add a CD changer to the Clarion Headunit?
LINK 1
LINK 2
LINK 3
Air Conditioning Problems - Info
LINK 1
Manual Transmission Issues
*Thanks to JMarkert for building this section*
The clutch pedal on my ng900 seems to have a lot of play. Sometimes the gears grind and it is hard to find reverse.
LINK 1
My clutch pedal feels very heavy, is there a way to fix it? AND I have to manually adjust my "self-adjusting" cable very often. Is there a way around this?
LINK 1
I'm sick of the whole cable issue. I don’t even want to bother with the manually adjustable cable. Can I put a hydraulic clutch in my car?
LINK 1
I’ve fixed the clutch cable, but I’m still having trouble finding some gears. Can the linkage be adjusted?
LINK 1
I've adjusted both the cable and the linkage, but it’s still very hard to find reverse. Is my transmission shot?
LINK 1
LINK 2
The linkage on my early ng900 feels sloppy. Can I upgrade to the newer style?
LINK 1
Can I replace the transmission myself?
LINK 1
How do I check/change my transmission oil?
LINK 1
What is the best oil for my manual transmission?
LINK 1
Model Specific Specifications
*These #'s are from GM Canada and may vary RE: US or European models*​
*1994-1995 Unavailable*​
2003 9-3 (SS and SE Vert)​
Modification Section
The "Clear Corners" Mod
Link 1
What is this MBC+A thing I hear so much about?
LINK 1
900S
LINK 1
Can I add a turbo to my N/A Saab?
LINK 1
900SE & 99 9-3S/SE (t-5)
LINK 1
2000+ 9-3S/SE (t-7)
LINK 1
would this be a mod FAQ as well? If so, maybe a link to redline's post about ecu decisions and comparisons.
All links fixed.
Yes, a mod thread as well. The whole second half is that.
Should I group the 99 with the 900's?
I don't want to explain stuff in this thread, just point to other threads where people have discussed these issues. Basically this thread is a bunch of SEARCHS so people don't have to do it themselves. Put the most common questions where people can quickly find answers.
In a little bit I'll be posting the list of upgrades I'll be doing with my car. I don't currently have links to "how to's" and the such, however included will be links to each part for sale. Some of them are more visual upgrades, however I guess they could still count as a "mod".
Edit:
Upgrade #1:"The Bare Bones"
A)Short Throw Shifter=$75
http://www.mpperformance.com/ng900.asp
B)Rear Sway Bar=$79
C)Sub-frame Brace=$49
Total=$203
Upgrade #2:"The Rice Eater"
A)Leather Shift Boot=$47.70
http://www.genuinesaab.com/catalog/product_info.php?cPath=26_31&products_id=53
B)Wood Shift Knob=$37
http://www.genuinesaab.com/catalog/product_info.php?cPath=26_31&products_id=54
C)Clear Little Fenders=$20.90
http://www.genuinesaab.com/catalog/product_info.php?cPath=26_29&products_id=32
D)JR Drop-In Sports Filter (with Cleaning Kit)=$77.60
http://www.genuinesaab.com/catalog/product_info.php?cPath=21_23&products_id=93
E)Air Intake=$100.80
http://www.genuinesaab.com/catalog/product_info.php?cPath=21_23&products_id=109
Total=$284
Upgrade #3:"The Pimp Kit...fo sho"
A)Upsolute Tuning Chip=$300
http://www.upsolute.com/eng/index.html
B)3-Spoke Double EVO Wheel=$139x4($558)
http://www.genuinesaab.com/catalog/product_info.php?cPath=37&products_id=164
C)B+G Lowering Springs=$251.30
http://www.drivewire.com/performanceparts/bg/saab900s2loweringsprings.html
Total=$1109
Grand Total=$1596
Stock HP=150hp
Increased HP=~30hp
Total Estimated HP=180hp
With my exhaust, that puts my car up to roughly 190hp. Which isn't too shabby, for a n/a. However most of those mods are either for handling/stability or personal comfort rather than performance.
OK. Started a fresh one, stuck it and locked it.
We'll let this one fall unless anyone has anymore immediate suggestions.
Do you like it better CENTERED or no?
1 - 7 of 7 Posts
