Time for a hood scoop.Have you taken hood off? Your cooling fins will touch hood if you dod not raise (or remove) it.
It does indeed and probably isn't that noticeable when the hood/bonnet is up. Mine clearly sags because I can see where it rubs on the top of the oil filler. In fact the gap between the engine components and insulation is so close I found my headlamp cover still sat on top of the battery housing the other day after I changed the bulbs about 3 weeks ago! (#crapspanneringWhen the hood insulation gets old it sags & rubs on the top of the engine.
This. Airflow is not going to affect heat transfer from the head to the valve cover to the DIC.The DIC will be at the temp of the head, which is a great heat sink. The head obviously won't get too hot unless the car overheats, in which case you have other problems anyway.
No but a wool blanket laying on top of the head/dic will prevent heat from escaping as easillyThis. Airflow is not going to affect heat transfer from the head to the valve cover to the DIC.
Re: potholders....how can that effort make a difference? Seems to me now you just have more stuff down there retaining the temperature of the combined mass.I also took 2 thin silicone potholders & cut them to fit under the dic in an attempt to reduce heat transferring to the coil pack electronic components. I think its helping but i cant say for sure just yet. Exhaust heat wrap is also your friend
Have you ever used it? it definitely reduces under hood temperatures. you should try it sometime. It keeps the exhaust gases hot by not letting them Escape out side of the exhaust pipe which in turn heats up the engine compartment . and by using silicone which is highly heat resistant. It should make a heat barrier. Like i said b4, i cant say for sure its making a difference but im comfortable saying it certainly isnt hurting it. Ive had it on a 2016 dic with at least 50k mi on it since ive had it, & no hiccups, stalling, or cracks in the black plastic cover to date. If you think about it the worst thing for electronics is heatRe: potholders....how can that effort make a difference? Seems to me now you just have more stuff down there retaining the temperature of the combined mass.
I don't know if you realize this but exhaust wrap is installed to keep the exhaust gases hot, not to provide any kind of cooling under the hood.
