Gidday Chaps, and Chapesses,
I am looking at a 2002 Arc, it has 110,000 km's, and I have a few questions for you:
1. There is a noticable shudder in the vehicle when I reverse, apparently it has had new engine mounts fitted recently? Would that have anything to do with the shudder, or would I also need new Transmission mounts?
2. The car was involved in an accident a while ago, and the front passenger door was repaired. It takes a little bit of extra effort to close the door, can this be fixed easily?
3. It feels a bit soft in the rear shocks, is this common in Saab's can anyone here recommend a set with prices?
4. It has walnut interior trim, and the piece around the lock/unlock switch is a bit damaged, and needs replacing, can just this part of trim be purchased, or do I need an entire new trim set from the dealer? Are there any aftermarket sellers of this part?
5. Is there a way to check the condition / health of the turbo?
6. Should I check out anything else, are there any common failures in Saab 95 that can cost me big $$ that I should have properly inspected?
