recently i had a few issues with my xenon lights flickering and even had one cut out on me completely, only to come back on at it's own leisure. i've also been generally unimpressed with the lighting ability of the HIDs over the past 2 years i've had the car. especially in comparison to the HIDs on my previous car.
well i took the car in to have the flickering issue checked and they said i had bad xenon control units (the metal boxes on the bottom of the headlamp). i guess these are aka the ballast?
anyway, they replaced the control units under warranty and recommended replacing the bulbs since they seemed to be dimmer than normal. so i talked with the parts guy and he offered a discount on two new bulbs so i took the deal. when it got dark later that evening i took the car out for a spin and WOW!!! the lights are so much brighter and crisp it's like they were previously covered with shades! they must be at least twice as bright as before. not sure which made the most difference, the control units or the bulbs, but i have renewed appreciation for the HIDs in this car.
i suspect both the bulbs and the control units were exhausted due to being run as DRLs by the previous owner, since the DRL function basically cuts the life of the bulbs in half because they're always on.
advice for those with HIDs: pull your DRL fuse. get your control units checked if you have the flickering issue. get new bulbs if you can. in my case it made a HUGE difference! very pleased with the lights now. :cheesy:
