New to me 9-5 Arc sedan
3284 68
Greetings, trying to keep the forums alive. Seems like everyone is migrating over to FB Groups.
(for those who are interested, here is my youtube channel. I try to document everything done to this car) - https://www.youtube.com/channel/UCDxRI82DI5xrL5yKQSxZBog
I recently sold my dream Saab - The Viggen due to moving out of state and couldn't justify taking it with me (long story). The Viggen was my 4th and favorite Saab and I was sad to see it go.
So when I moved, I was on the search for another. I posted on the local Saab FB group with 2 conditions - It had to be manual and under $1,500. I got a few responses. One of them caught my eyes (mainly because it was $850 :LOL:). The owner worked with me down to $700 and it was a deal!
This is my 2004 9-5 Arc. It was sitting for a bit because the previous owner bought a new car and has not been used. It runs and drives remarkably well. Still a mystery to me why the owner let it go for so cheap. Maybe one day I will find out (hopefully I don't haha). It has zero rust, not even a speck! This is new to me because I am from the rust belt. It was weird to see an old car without rust!
Tire Wheel Car Vehicle Automotive parking light
Has 165k miles on the clock
Speedometer Trip computer Odometer Tachometer Vehicle
It is indeed a manual :p
Vehicle Car Hood Motor vehicle Automotive lighting
The first thing to do was to give it a good exterior wash. Body panels are in excellent shape, I could see no dings or dents, just a few scratches in the common places.
Automotive side marker light Automotive parking light Wheel Tire Vehicle
Wheel Automotive tail & brake light Tire Vehicle Car
Next on the list is a good interior detail. It needs it badly haha.
I am also documenting the progress on my YT channel.
61 - 69 of 69 Posts
Discussion Starter · #61 ·
I fished out a few more goodies from the parts car today.
These cool B-pillars with mesh pockets!
Tool Grey Automotive exterior Kitchen utensil Synthetic rubber
fun fact: They took out this reinforcements on the 2004 models. Cost cut by GM probably.
Tool Bicycle part Auto part Gun barrel Metal
Much better :)
Vehicle Automotive tire Automotive design Chair Vehicle door
And the homelink mirror!
Automotive side-view mirror Vehicle Motor vehicle Automotive mirror Automotive design
Before:
Automotive lighting Automotive design Hood Automotive exterior Vehicle door
During: I tapped into the sunroof motor harness for the ground and switched power (red/blue) wire. Just connecting these gave most of the functions. I think I'm missing the function where the auto-dim stops when in reverse but I can live without it.
Circuit component Passive circuit component Hardware programmer Gesture Finger
After:
Vehicle Car Motor vehicle Light Automotive mirror
Video summary:
So the accountant talked the lawyer into telling the engineer about the pillar re-enforcement delete and the Swedish engineer says..."it's okay, I'm not planning on buying one of your cars for my family anyway".
Discussion Starter · #63 ·
Made some small progress on the Sharktooth today. Having a 4 year old and a 1 year old, I don't find much time to work on it but...you eat an elaphant one bite at a time, am I right? haha...
Hood Motor vehicle Automotive lighting Bumper Vehicle
In addition to the hot staples on the back side, I filled in the cracks between the upper grill and the rest of the bumper with this product. This stuff just works, cures to a solid but flexible bond.
Hand Liquid Automotive tire Cosmetics Finger
Still got a lot of sanding to do. But after I wrap up with the sanding, I am moving onto plastic body filler.
Automotive tire Automotive lighting Hood Motor vehicle Automotive design
Also bought an orbital sander from wish.com. Believe it or not it's actually pretty good. Even if it lasts for just this job, I think it's worth the $20 bucks.
Glove Sports equipment Gas Bumper Font
Discussion Starter · #64 ·
Recently got a tune from Saabtunerscott. I told him I have a stock 9-5 Arc and he gave actually gave me the stage 2 tune since the Arcs have the same engine and turbo as the Aeros (except for a few things). This is the numbers that the ECU calls for. 282hp and 316 lb. tq. (430 nm).
World Font Parallel Number Paper
Super easy to install. After sending him the VIN and Immobilizer code, he sent me the stage 2 ECU (no need to send your ECU) via mail. Then all I needed to do was swap the ECU!
Location of the ECU:
Automotive tire Motor vehicle Hood Automotive design Car
After putting in the ECU, I actually realized that I had a boost leak (there wasn't much difference with the new ECU in the car so I knew something was wrong).
Sure enough, I had a bad check valve at the 1 location below.
Line Font Motor vehicle Automotive lighting Gas
I made the update to the system so that it is the same as the face-lift 9-5s by eliminating the red hose in the above picture. This is a common thing to do for those of us still on the old system.
Doing this, you only need 1 check valve. I replaced the plastic one at the 2 location with this aluminum one, and also replaced the lines.
Motor vehicle Automotive tire Hood Steering wheel Auto part
Much better!
Motor vehicle Automotive design Automotive wheel system Auto part Automotive exterior
The tune completely woke up the car and it now spins tires on 2nd gear during a roll which has never occured before. Time for new tires soon!
Video summaries:
2005 Saab 9-5 Aero Sedan '98 corolla until my 9-5's engine is finished:'~((
That seems pretty aggressive for completely stock hardware (Aero or arc has hardware is the same, as you said). Be careful with EGTs and internal temps.
Discussion Starter · #67 · (Edited)
I finally had some time to finish up the Sharktooth bumper!!
I started by JBWelding all the cracked portions
Automotive tire Wood Gas Tints and shades Fender
Hand Leg Plant Human body Gesture
Automotive tire Window Automotive lighting Finger Vehicle door
Hood Automotive lighting Automotive tire Motor vehicle Tread
Then onto some plastic body filler
Hood Automotive lighting Motor vehicle Vehicle door Bumper
3 coats of primer
Automotive tire Hood Bumper Automotive exterior Motor vehicle
There were some spots left to fill in so I used this:
Automotive tire Liquid Fluid Automotive wheel system Gas
Then onto 3 layers of base coat.
Hood Automotive tire Motor vehicle Automotive lighting Automotive design
It didn't come out all that great since I didn't have a proper paint gun, but I wasn't expecting perfection so I pushed on lol
Before:
Automotive parking light Car Automotive side marker light Wheel Vehicle
After:
Car Automotive parking light Vehicle Vehicle registration plate Automotive side marker light
This was my first time doing body work and it was very difficult so I have a new appreciation for body shop technicians. It looks pretty decent from 10 feet but leaves a lot to be desired up close.
But I will wear it proudly since it was my own work from start to finish!
Video summary:
Discussion Starter · #69 ·
That looks great!. The difference in expertise required to look good at 10ft and up close is immense. Having a proper paint booth is one of the major other factors though.
Thanks! Yea it's all in the pain-staking little details, and definitely experience! It was a fun learning project with not much at stake since I started with a pretty pathetic junk sharktooth. I will continue to search for used sharktooths locally haha
61 - 69 of 69 Posts
