Hi friendly Saab folk,
I recently bought a used 2007 Saab 9-3 2.0t in the USA (had a 1.9 in the UK). It runs very nicely but there are a couple of issues, which may be related. The AC one is the biggest practical issue for the moment:
AC sometimes runs at first, but very quickly stops blowing cool air when car is up to temperature. It seems erratic but it once started blowing cool again when I was stopped still (car was up to temperature). Often it doesn't though.
I replaced fuse 36 just in case, but that made no difference. The compressor is running and the clutch kicks in when the Aircon comes on. Freon reads as normal when cold (gauge didn't work when Aircon wasn't blowing cold). It may be unrelated, but the fan doesn't come on to cool the engine when I stop the car, like the one in the UK did, even though the weather here is very hot. However the temp gauge reads normal temp. It starts cool and goes to normal temp when running, so I don't think this gauge is faulty. There was a note in the last service that the radiator had a small leak (they recommended replacing the whole radiator) but I again don't know if this is related, just wanted to give as much info as possible. I can change fuses and do minor things, but not really a mechanic, just wanted your honest advice. Thank you!
