IMO, those were either cracked before the install (dropped/mishandled in shipping, etc.) or cracked during the install (a little wobble of the socket is all it takes, not hacking on your install)
I'm still wondering if you used a spark plug socket with a rubber insert?I'm still wondering how I managed to break 3 ?
OK guys, giving this another shot. I bought 8 new plugs and a new DIC. If I somehow break 7 plugs I'll give my beloved '05 aero wagon to a more deserving soul. She deserves better.I'm not saying the socket you used is the problem but the construction of your socket compared to the one I have been using for the past thirty years is somewhat suspect.
The arrows I have inserted in your picture point to areas that have no bolt/plug contact area and can easily lead to leaning the wrench over when you are either torquing down or removing a bolt or spark plug.
Why any manufacturer would opt to remove so much surface area within the bolt/nut/plug chamber confounds me?
Is it that much cheaper to produce?
Okay I'm going to say it....that is a garbage socket!
That will only give him a terrible starting point. :cheesy:If it does suck, it'll be a good starter set for my younger brother.
...minus the plug socketThat will only give him a terrible starting point. :cheesy:
I've seen those sockets before, and the manufacturer said it was so that they don't put pressure on the points, which is supposed to eliminate the chance of rounding off the fastener. They're designed to only put pressure on the flats.I'm not saying the socket you used is the problem but the construction of your socket compared to the one I have been using for the past thirty years is somewhat suspect.
I'll also compare my Costco "made in Taiwan" socket to Sears / NAPA. If it does suck, it'll be a good starter set for my younger brother. We're looking for a cheap 9-3 / 9-5 in South Florida.
thanks all ![/QUOTE
Dude dont buy that junk its a waste of money.
If you want to start working on your car the right way without frustration,
Buy Snapon Tools Period. Check fleabay or CL for used
1st thing metric wrench set
2nd 3/8 drive ratchet and chrome deep sockets
That may be an explanation of sorts however I prefer a socket that mates properly and minimizes the chance that a lateral or misaligned force can occur....especially on spark plugs.They're designed to only put pressure on the flats.
Agreed. It seems clear what happened here ; plus most folks don't torque sparkplugs. 15 ft lbs. Where there is a compression gasket on the plug ( not all have that ) should torque then loosen the re torque. No one that I know or , when using spark plugs with a threaded top connection , remove the top connector, crimp the threads and re attach. BITD that top connector would unwind with vibrationThat may be an explanation of sorts however I prefer a socket that mates properly and minimizes the chance that a lateral or misaligned force can occur....especially on spark plugs.
