1 - 18 of 18 Posts
2001 saab 9-5 with 2007 engine.
I have a high idle (1500rpm) and a p0444 evap circuit open after first starting the car. I attempted to track down a vacuum leak but could not find an obvious one. The issue was not present before the engine swap. Not sure what I am missing. Any help would be appreciated! Besides that the engine seems to run smooth.
Update idle fixed. It was a stuck cable. I still have that error code but i do not see a vacuum leak. I inspected the entire evap system in the engine bay. The only work i did was pull the engine and transmission.
Discussion Starter · #2 ·
Still have the evap code however.
Would the 'turn on an unlit propane touch and scan the vacuum lines checking for engine rev changes' be an option?
It refers to an open electrical circuit, not to an open evap / air system.
Most propably you forgot to connect the evap valve.
Is there a wiring diagram that I can use to trace back this connector? I used my multimeter and both legs of the connecter to ground and there was no resistance. So it is definitely open. Does this plug go through the main wiring harness? It does not appear to. The line goes into the firewall.
As always, all data is available on WIS, even online.
I am not sure what you measured.
With running engine you should measure at least battery voltage (versus ground) on one side of the connector. As the engine is running and if there is no battery voltage, maybe there is broken cable between junction J18 and connector.
Measure resistance of EVAP valve, should be around 45 ohm.
Resistance was 45 ohms and there was a solid 12+ volts from one leg to ground. I will trace the line back and see if I have a break somewhere.
This weekend I am going to run a new ground and see if that fixes the problem. If it does I will track down the broken ground in the harness.
What ground? Evap gets ground from trionic.
Sir, do you have an 02 or newer? I have a feeling the wiring harness I used is the issue. My car is an 01 and the 04s had a different evap purge valve. If you have the newer style could you take a picture of the valves connector and the plug that connects to it?
Thank You,
Barry
Motor vehicle Hood Automotive tire Automotive design Bumper Automotive tire Bumper Finger Bicycle part Automotive exterior Hood Motor vehicle Trunk Automotive design Car
2003: original wiring harness and EVAP valve.
I have no other picture of the older model available, but may remember them to be different.
e.g. random ebay search for part number:
View attachment 284478 View attachment 284479 View attachment 284480
They are different. The plug is completely different. I am torn between trying update the purge valve and system to the 02-04 variant or putting the other wiring harness back on now that I have repaired the j-16 connector on it.
How did you plug the connector into the EVAP valve, if they do not fit?
Why dont you just snap the short cable with the connector off and solder it to the installed wiring harness, with some glue lined heat shrink tube for water protection.
The connector on the 01 is the standard saab type with the red slide release. The wires are against the strut tower and make there way back against the firewall.
Does the connection on your harness enter the harness in the same bubdle as the maf connector?
Fixed!
I was able to splice in the newer valve from the junk yard into the existing hoses. The code did not come back.
1 - 18 of 18 Posts
