I just put in the new clutch on my 95 9000CSE. Its making an awful noise. Sounds like its coming from the thowout baring. It sounds like when you have a bent fan blade on an old style car that was hitting the shroud. A high pitched singing as it were. After driving around the block it got better. I'm hoping that the baring either had some grease on it and is spinning against the pressure plate or the flywheel is hitting against the aluminum shield on the bottom.
Has anyone else experienced this? I REALLY do not want to take this apart again to replace the baring....:evil:
