Malibu said:
The two popular choices around here are the Infinitys (Kappa or Reference), and the Boston Acoustics FX3s....
I have the same disapointment with my 05' 9-3 Arc (with "Drivers Package") that has the Saab Infotainment (13 speaker/300W) with in-dash 6 Disc CD. It has too much mid range and not enough low end. Turning up the BASS knob just makes the low end muddy and doesn't really help. The back speakers (using the fader) don't sound tooo bad. But the front is aweful.
Your comments about chaning the front speakers sounds like it will help. Mine is a lease, so I dont want to mess with replacing the amp, head unit, etc... However, just the speakers sounds good.
Question...
The BA FX3's are listed as a 4 Ohm, 92 dB sensitivity, 100 - 20kHz frequency response, 12 - 60 Watt rms.
The Infinity Reference 3012cf's are listed as 4 Ohm, 90 db sensitivity, 85 - 21kHz FR, and 2-25 Watt rms.
The Infinity Kappa 32.7cf's are listed as 2 Ohm, 95 db sensitivity, 85-25kHz, FR and 2-35 watt rms.
I thought the stock speakers are 2ohm, but he BA's are 4. So do I want 2 ohm or 4 ohm speakers as my replacments?
Due to the lower sensitivity, the Infinity References would probably be more "quite" with the same power, so I think I'd rather have the Kappa's or the BA's.
How is the "low" end on the BA's? (I'm leaning towards them as I can get them at the Tweeter store down the street)
Any suggestions on "local" stores that might have both to be able to compare?
I've seen info on the back, but I haven't found any How To's on replacing the front speakers? i.e. taking everything apart to get them out? Or the front/Center speaker (by the SID).
