Hey guys,
So if you saw my other recent post about strange front O2 sensor behavior: https://www.saabcentral.com/forums/showthread.php?t=726842 that seems to have been resolved with a new sensor. I still can’t rationalize how unplugging the sensor caused it to fail, but after installing a new Bosch #16623 ($58.78 from Amazon), normal oxygen sensor function has been restored.
BUT, even with the new sensor my car is still failing to complete the front O2 sensor diagnostic readiness, despite fairly extensive driving in a manner that should allow the diagnostic to complete. I should add that about 9 months ago I replaced the ECM with a new part sourced from Orio and programmed by them (and married to my car by me). Since that repair, the car has run great. Prior to the ECM replacement, there has never been any trouble with getting all the OBD monitors to run and set their respective readiness bits. So, my suspicion is that the calibration file loaded into the new ECM by Orio has some problem with getting the front oxygen sensor OBD diagnostic to run, or complete and show as ready. I discovered this after my car failed smog check as “incomplete” due to the front O2 sensor readiness bit not being set.
My thought is to bypass the state referee circus that will entail to try to get an exemption and just simply install a different ECM that has the original Saab calibration files (just add the module, no SPS). I am not an expert on what will work so I am hoping the community can help me out. So here goes with a few questions:
1. My car has a #55567225 ECM. I have found this part online at various auto salvage yards, from various model years (2009, 2010, 2011). The concern is that the mileage of the 2011 and 2010 donor vehicles is high, over 150K miles, so I am worried that the ECM’s from these cars may not be in great shape (my ECM failed at about 50K miles). The 2009 has a little lower mileage. Are all the 55567225 ECM’s interchangeable among the various model years? That is, can a 2009 55567225 ECM be married to a 2011 car as is with the existing calibration files unchanged? SPS is not an option for this job, I need to be able to retain the existing cal files.
2. Assuming the answer to 1 is yes, then will there be a problem with the VIN mismatch of the replacement ECM and my car? I have a Tech 2, and I will be buying security access from Orio since the cracked globaltis will not work for my 2011. Will the Tech 2 just recognize the car’s VIN and reset the ECM VIN based on Tech 2 user input?
3. If it works, this will be a temporary fix and I will be re-adding my existing ECM back into my car once I get the smog check done. Last time, I “removed” my old ECM with Tech 2 before adding the new ECM. Is the “remove” process necessary or can I just swap the hardware and “add” the replacement ECM? I would like to avoid the extra step of removing/divorcing my existing ECM if possible.
Thanks in advance for any advice on this!
