Hello, I am new to this site and I would like to welcome you. For the first time I am the owner of a SAAB 9-5 SE since 1998 with a B205E engine. And I have the following problems that I am facing.
1.the wrong vacuum line or at least I think because of the lack of 2 hoses, I searched the net and found several schemes but unfortunately none was the same as the one of my car.In my car there is a valve that leads to the throttle body. I replaced all the vacuum hoses but unfortunately I did not take a picture before changing them.As a result I used a diagram on the net but that valve does not appear here.
2.In my city I did not find a mechanic with a Tech2 tester so I had to take it piece by piece I also changed the coil after the vacuum hoses but the car still did not seem to work well, finally I found a mechanic with tech2 and I did a check, the answer was the throttle not working well so I took about 4 used throttle because a new one is very expensive for us (I must say that I live in Romania.) Now the engine is going well at relays but when I want to change gears the mower has a tendency to stop. So I decided to ask for your help because I honestly fell in love with this car even though it is quite old. So I decided to keep it alive. I'm sorry my English is not so good, I hope u will understand me. I will attach some pictures. Ever since I took the car I have exchanged oil and filters (I used Mobil oil 10w40 at the advice of a mechanic who told me that the engine is a bit old and to put this oil). But from what I read on the forum I saw that recommend 0w40.
But I could not remove the oil bath because the suction in the oil bath was cleaned, this is the next step. So in conclusion the car does not go well and I was left without ITP inspection so I have to set it up. That's about it and I need some great advice and much help from you.
Something else on the vacuum line was missing 2 hoses so I used the diagrams in the pictures attached but in this case the valve that came on the throttle does not appear so I do not know how to do it, probably because of this the engine is not working properly.
![20190927_160637_HDR[1].jpg](/d2/attachments/64/64634-d532208f44514260448f97c01187e670.jpg)
