Sorry for my first post to be a problem one, but here it is.
I recently purchased a 1987 900 4cy auto. I bought it because it has only 92K on it, and I know that guy that owned it. The car had been sitting for 3 years.
I am having a problem with the alternator not charging. I read previous post under the search engine, but found nothing to solve the problem.I read where the ground was possibly bad, so I ran 3 grounds off the alternator. 1 to the body, 1 to the engine, and 1 directly to the battery, none helped.
I installed a new battery when I bought the car. I took the alternator off and had it built by an alternator shop here in B'ham. I put it back on the car, still not charging. I went and bought a used alternator from the pull a part, had it checked before I put it in. The alternator showed good. I put it on the car, and same problem, not charging. The voltage starts of at 12.84 and steadily drops.
It will get down to 12v and then I just turn it off.
Any help would be appreciated as I am new to this whole backwards engine thing.
Thanks.
Eddie
Thanks.
Eddie
