I have a 2007 9-5 and have had two problems over the last few weeks. Saab service folks are baffled. I'm hoping you all can help.
1. Car won't start randomly (completely unrelated to when the last time I drove it...could be 15 minutes, could be 15 hours). Voltmeter reads 12.37 at these moments and so battery (1.5 years old) is fine. Lights come on but no crank noise. Will start after jumper cables on there for about 10 minutes (though once it took 20). Car occasionally sputters in idle, too. Saab checked battery (and possible drains) and alternator. All okay.
I'm wondering if there's a chance this is all related to my other problem #2, which seems to coincide in terms of timing.
2. O2 sensor replaced about 6 months ago, all fine until 2 weeks ago. Right before first crank failure, the check engine light comes on and the code is for O2 sensor. Car failed to crank twice after that. Saab replaced O2 sensor when they checked for start failure. For 2 days no problems with starting the car. Then yesterday check engine light on again (coded as O2 sensor) and the next stop, start failure.
I have no clue if there's a possible connection here between 1 and 2 or if there is something else I'm missing. Saab did not say specifically that they checked the starter, but they said they checked everything that could be causing the problem. Do the symptoms for the start failures sound like a starter issue?
