Before I started messing with Saabs I had a 1986 Maserati Biturbo (86 and older were turbocharged and carburated- really ghetto). They both suffer from a similar problem- non standard wheel lug paterns. While I had the Biturbo, Momo began making these special lug nuts that they called Magic Nuts. They are kind of hard to explain so please refer to the pics. They are 2 pieces forged together that consist of the 60 degree taper that mates with the wheel and the lug nut itself. The lug nut "floats" on the taper which allows 1-2 millimeters of side to side play. This allows the use of 5x112 lug spacing on our 5x110 hubs as the difference in only 1mm when the wheel is mounted . The cool thing about this is that there is a LOT of 5x112 wheels available with perfect offsets and bore centers for the front wheel drive Saabs. I have been using them for about a month on my 99 9-3 vert. with absolutely no problems.
The downsides are:
Momo hasn't made them in 2 years. I was able to track a set down with a couple phone calls to wheel retailers. Seemingly, retailers who sell Momo might still have a set or 2 on their shelves.
The hubs must be studded. The factory wheel bolts have to be changed to studs which I prefer anyway as it is easier to mount.
Hubcentric rings *MUST* be used.
The Magic Nuts are pretty big (diameter is about 1 1/8") and cannot be used with tuner lug type wheels.
The downsides are:
