So I finally got my hands on the MP Perfomance rear sway bar, and when I went to install it, I sheared off the first bolt on the existing sway bar. Anyone know of a good way to fis this? If not, can I just leave the sway bar with the sheared off bolt?
Thanks for any help.
Andrew
These can be very tough to get off with corrosion. If I remember correctly the sway doesn't have threaded holes, so whatever you can do to get that off. You just have to rough with it. You do have the new MP bolts, right?
Happened to me too. Used the claw end of the hammer and it pried right off. Just be carefull of the brake lines.
ALL 4 did that on me, took a grinder to one and the rest were pried out with some chanel locks
