1 - 20 of 32 Posts
I've been reading around the forums for a few days making a list of things I want to do to my car. I'm 17 years old and drive a 2001 9-3 2.0 T7. I have many things I want to do but I want to find the absolute best prices for the US.
1.) 3"Downpipe
2.)Lowering Springs
3.)6000K HID kit :cool:
4.)Intake
Any ideas as to what I can do for around $600? I am in desperate need! I hope I'm not already annoying you guys ;oops: - I've search around already, just in search of opinions now. Thanks!
Taylor
forget the Hid kit, as that will take about half that money right out... go with suspension mods, because just a downpipe wont do anything. u either need a lot of hardware or none at all.. u can try an smbc, tht will cost u all of like $40 and will net the best gain...
G
I would mix it up:
MP or GenSaab 22mm Rear Sway Bar $90
MP Steering rack clamp & brace $150
SMBC $50
DIY 3" Intake with K&N filter $50 or some other intake
Save the rest for 17" wheels & tires or better exhaust.
Ice Man said:
I would mix it up:
SMBC $50
Double ditto. These first mods will tighten the car's handling A LOT and will unleash some ponies you didn't know you had. This way, you can mod slowly and bring your car up to the point where you'll do all the hardware mods you can do...
Look back at some of Rico's posts. He did it exactly the same way....
Welcome to SaabCentral!
I ditto doing the basic suspension stuff mentioned above. These little mods do soooo much for the car. Definatly money well spent.
The thing with the springs is that they really won't do anything without upgraded shocks/struts. Actually they're probably hurt things. Unless you plan on doing the install yourself, and don't mind doing it twice, it makes sense to do springs and dampers at once. This too will make a huge difference, but its costly. And if you did this before the other smaller braces and such, it won't be as effective.
The fact of weather a mbc works on a T7 or not is hugely debatele. Search around for this sort of thing and you should find lots of arguments. The people who have put these into T7's seem to use the smbc. I'm not sure if these are the only ones that work or not, that would certainly explain why they're used.
Discussion Starter · #19 ·
So how am I supposed to do anything with a T7 intake:roll:? I really don't want to spend much money on an intake- I've gotten about $1300 for graduation total so maybe I should just spend all of it at once and get a nordic or BSR package- any ideas??? Thankyou so much!
save your dough and i wouldnt buy an ecu immediately, rico is pushing pretty big numbers wiith all kinds of hardware and stock software. especially considering t-7 ecus cost 1000! you can tak eoff the lower portion of the intake tubing of t-7s and buy a higher flow filter, but with mafs, oiled filters can cause trouble. an intake for t-7 from genuine saab costs 160.
1 - 20 of 32 Posts
