Hello Everybody,
I'm new to this forum,
I own a 2002 Saab 93 2.2 TiD 125Hp that has around 230K km (almost 150k miles dunno what kind of units you use...)
I do most of the things I can do on my own on the car, and recently, after a diesel filter change (under the car right next to the right rear wheel) I noticed my car lacked a looooot of power and finally the orange Engine light turned on (the one under the temp, not the Check Engine one)
After the filter change, it was real hard to get the car to start again (all it did was start and stall almost instantly) but after numerous attempts it started again. I took it for a quick ride, but something wasn't right, felt like the car had no guts, even pedal to the metal in second and third gear and then the Engine light came on. It isn't in limp mode cuz I can get it to 120km/h (~75mph).
I checked the fuel tank cap, it's tightened, I tried my OBDII reader, and it couldn't find any fault ! The engine light goes off when I shut the engine off and only comes back if I try to accelerate hard. Car was working perfectly before I changed the filter so I guess it's what caused it...
Could it be a lack of fuel pressure (air entering the fuel circuit somewhere) or residual air from the filter change still in the circuit? Dust in the injectors? Any ideas?
Thanks for reading me and sorry for my english, I'm french
