21 - 29 of 29 Posts
Yes, 1 seal is inside the pump under the metal cannister. Easy peazy. If #4 isn't getting sufficient fuel (as it is furthest) then sounds like a fueling issue. Have you checked fuel pressure?
Discussion Starter #22
I did, 2.4 bar at idle and 2.9 bar under load, yet I discarted that possibility since with different spark plugs, 1 and 3 are the ones with the higher misfire counts...
if it was me i'd be going to stock plugs to see if the misfire count is still high..T8 is picky when it comes to plugs...
get rid of the bosch and fit oe and report back NGK PFR6T-10G or D..
Discussion Starter #24
Orinigal SAAB/NGK PFR6D-10G are mounted right now, tried 3 different sets of spark plugs just to diagnose. Misfire count with OEM spark plugs reaches 3 digits in a few minutes.
Discussion Starter #26
Discussion Starter #28
Is there a chance that you could check with the previous owner of the car if it was remapped? By the way are you in the UK?
I did, he told me that at some point they had to take a look at the ECU because the car was not running as it should, but that's all I could take... I'm from Spain, but parts are way cheaper over there with current pound to euro rates.
you won't eliminate misfire counts they will always be present,if I went to scan mine 2moro the misfire counts would be high..
21 - 29 of 29 Posts
