Hello!
I have just purchased my first Saab, it's a 2003 9-3 2.0T, with 95000KM on it. I purchased from a dealership, when I first got it, it had a very bad misfire at all times. Dealer replaced a coil (non OEM) and replaced all spark plugs with NGK (proper gap) and misfire went away. Now, the car runs great, except if the engine is still below operating temp (driving normal), or when running at full boost (just below the red line), it feels like it is either misfiring or has a fuel cut. I have been driving it for 7 days now, and there have been no check engine lights except for a P01455, which I believe is related to my fuel sending unit as my gas gauge doesn't work. Runs fine at idle, low and medium boost. The "chugging" occurs at any gear, any speed, only at full boost (or when the engine is cold)
I will be replacing all 4 of the ignition coils with OEM, I am just trying to save some money before I do so. Is there anything else I should look at or is it my best bet to start with the OEM coils and then troubleshoot? I am only hesitant on buying the coils immediately because there is no CEL, which leads me to believe it is an over boost issue.
Pardon my ignorance, I am still learning my way around the car.
Any insight is appreciated.
Thanks!
Thanks!
