1 - 2 of 2 Posts
Hi fellers. Just want to share a real simple fix I learned somewhere online recently for a long crank time / delayed start. My 1998 900 SE was firing right up every time, and then that changed suddenly. According to The Fix, I disconnected the negative battery terminal, then turned the ignition switch to On, waited about 20 minutes, turned the ignition switch to Off, reconnected the negative terminal, and BOOM - she fired right up like before. I don't know why this worked, but it did!
1 - 2 of 2 Posts
