Is there a difference in these bolts? The subframe itself is the same (crosses over). The threaded inserts are the same for middle and rear. The front screws and rear screws are the same. But the EPC lists a different bolt for the middle. Torque settings are the same spec.
Anyone compared them side by side?
EDIT: Ignore this post. The centers ARE the same. It's the early NG900 that uses a different bolt in the rear (must be related to the stanchion arm change). I always remember the rear as the 14mm and the center as the 12mm, and that's exactly backwards.
