Metallic "crunching" noise in front suspension when turning
Hi there. About 6 months ago my '89 900 EMS started making a pretty horrible loud metallic crunching noise in the suspension or driveshaft on the left hand side whenever I did a right turn, (unless it was a very, very, gentle and very, very wide turn). This was really only noticeable at the low speeds you'd use turning into a park spot, going around a roundabout or doing a u-turn. It certainly got me lots of surprised looks and raised eyebrows in the supermarket carpark. At higher speeds it doesn't happen - probably only cos you don't turn the steering wheel anywhere near as much when travelling at speed in a relatively straight line. (Well I don't anyhow!)
The sound is quite torturous, but nothing ever fell off, and oddly, for a period of about a month it actually stopped doing it. Some months ago my mechanic whipped the wheel off and had a quick look but could not see anything obvious. The car has sat idle since then but I now want to get stuck into it, fix whatever it is and start driving again.
Any suggestions what it might be? I can only it's think something in the suspension or a CV issue, but I don't want to end up with the car in more bits than necessary to find out. Are there clues I can look for to zero in on the problem, or a logical way to eliminate any usual suspects for this in a C900?
It's worth mentioning that there is NO noise like this whatsoever, from the left or right hand side when driving under any other conditions.
Could this be ball joints?????
