Is anyone dyno'ing this weekend in carlisle. Fish and I are considering heading to carlisle with his test muled stock spg that's running MS. We've tuned it focusing on driveability for the last year. All seems to be fitting..it's running twice as nice as stock w/ 20-30mpg and 12.5/1 afr in boost and great driveability in the city.
We've been considering putting together a plug in package if anyone else is interested. That involves a oem ecu box that plugs right into the harness and then just two jumper cables w/ a modified IC-TB pipe. Only the timing would need adjusted, so it would be easily reversed. I've designed adapter/daughterboards and modified the code specific to the C900 LH2.2 and LH2.4 application.
The features are quite nice:
12x12 Fuel map
8x8 AFR map
NB & WB O2 compatibility
Prog Over boost ( get rid of that little vac switch under the dash)
Prog rev limit (Ign and/or fuel)
12x12 Ign map
Knock detection
Intake and Coolant Ign Retard
Accel/Decel Enrichment
Logging (rpm, map, afr, DC, intake temp, clt temp, knock, etc...)
Modified Code for:
A/C Idle compensation
Charcoal ELCD function
2 & 3 pin PWM Idle control
Optional:
12x12 mapped PWM output for h2o inj (aquamist HSV)
12x12 Fuel map
8x8 AFR map
12x12 Ign map
Knock detection
Modified Code for:
Optional:
