My battery has died a couple times recently. Once after just sitting inactive for a month. Would not start. Then again after using the radio (only) for about 45 minutes a few days ago. Hardly the sort of draw that should kill a battery. I used to listen to the radio, with an old battery, in cold weather, through two or three hour-long cycles when working on the car, with no ill effects.
The battery is only about a year old. I believe it's a Johnson Controls battery (relabeled, of course) and those are usually good for five years... perhaps three in this hot climate. I'm not in a cold climate so it's not a cold-weather thing. Definitely seems premature.
Alternator shows 13.6 volts at the battery when idling / charging. It's a Bosch, replaced also within the last year or so (was definitely having issues). Battery was replaced after that. After driving just a short distance (jumped car to start), battery showed 12.6v. so charging seems fine. I did put it on the charger for a few hours and charged it back up to full charge.
The failure a couple days ago (radio on 45 mins) was after a ten minute drive. I figure that if it was mostly discharged before starting that perhaps it didn't have time to re-charge on the short drive. \
TL; DR: -i.e. the real question:
I know it could be a bad battery, but to the point of this long post, I think I should measure car-off draw before asking for replacement under warranty.
I know some circuits time-out after an hour. I'm thinking that I need to hook up the ammeter between the battery and the main positive lead, let the car sit an hour, then look at the draw. I figure if I do anything like open a door that I might trigger a reset on the hour wait.
Thoughts on that? How much draw should I see initially and then after an hour?
Also, do I need to tie down the hood alarm switch? My alarm is "not installed" in Tech II, but I suspect it still draws current in that configuration.
Thx,
Thx,
