1 - 11 of 11 Posts
Some Saabs were equipped with a temp sensor in the catylatic converter. If the cat converter got too hot, the EXH alarm on the instrument cluster would light. I don't remember how hot it needed to be, but it was hot! When it cooled off a little (10-15 degrees Celcius) the alarm would go away... Ron
stupid question,but needs to be asked! If the sensor stopped working, would this have an effect on the general performance?
Yes and no
If the car was running poorly(incomplete combustion), the catatlytic converter would be stressed - which is not good and its costly. Otherwise, this sensor would have no effect.. It seems like a good idea, maybe...
Is the light on when you first start the car and the cat is cold?
If so, the sensor is probably defective, but I don't know anything about this sensor, whether it can be replaced or if the cat needs replacement to change it.
We don't have that sensor in the US. I'd try looking at it first. Maybe the cable got melted by the heat and there is a short-to-ground in the circuit now... Ron
OP> If you are talking about the 9000 in your profile you are in the wrong forum area... try the 9000 forum for better responses (this is for NG900 and 9-3).
If it is anything like the older classic 900 the EXH light would come on when it is time to replace the o2 sensor.
Try the 9000 forum area tho!
sab
1 - 11 of 11 Posts
