just got a 96 900se - already seems like a very quirky little car but love it - however, went to get gas and can't seem to figure out how to release the gas cap door (without prying it open with a screwdriver, and i don't think that's what you're supposed to do) - doesn't seem to be a button, switch or anything anywhere in the car - help! :confused:
Assuming that the '96 is the same as the '95, there is no gas door release. There is a locking mechanism that operates with the door locks. When the doors are unlocked, the gas door unlocks at the same time.
I believe that there is a pull-cable in the trunk, behind the cloth liner inside the fender, that will pull the lock back if there is a malfunction.
John
In the boot, upper right side, there is a rectangular imprint. You may have to cut this partially open, making an access.. Lift this away, underneath are the fuel door lock mount screws.
There is also a screwdriver in the spare tire compartment which should fit..
Manual, p 83
Motormom said:
will check the pull cable in trunk - might be a malfunction, doors were unlocked . . . thanks!
...and that's nowhere near the dumbest question...
That's actually pretty enlightening. Now other folks know what to do if this happens to them...:D
