1 - 13 of 13 Posts
Can increasing the pressure by 0.3bar get more power? If the emergency mode does not switch off and there is no overboost (9-5 170hp chipped + -230hp)
I got 1.3 bar bypassing the boost control valve.
Can it? Sure, provided you’re getting the appropriate amount of additional fuel to support it...!
I think, if there is no overpressure, the ecu is already able to adjust the fuel
I’d never take that for granted. Tuning your car involves reviewing what is really happening, not just turning up boost... ;)
Only when i chipped, they told me to put the aero turbine in because it was already tuned for more stimulus, they said they put on a chip that corresponds to aero stage2 +-300hp
Just to clarify a few things. 1.3 bar is approx 18 to 19 PSI, without boot-cut the computer "should" be able to adjust. The system already runs pretty rich at max boost so I don't think you'll have a problem. That being said, small turbos always "spike" or overshoot their designated boost pressure and without boost cut you will spike to 20 or more PSI. This could lean out the mixture and could cause damage theoretically. T7 cannot infinitely calculate the proper fuel for air mass volume, but that should be within the stock parameters. Also, why did you bypass the boost controller? The system works very well and rarely fails on T7...
Sorry if I'm thread highjacking, but yesterday I tried to run Torque App and measure intake pressure. It updates super slowly, but in a third gear pull I saw upwards of around 28 psi. Is that too much?
My car is a 2000 9-5 Aero with stage 2(I think) BSR tune and exhaust.
Ups maybe I read the wrong parameter.
I'll have to look at my settings, but if I recall correctly, I have the Turbo psi reading from the MAF sensor. You can have it read from the MAP sensor as well. I believe when it was reading from the MAP sensor it showed WAY high psi. When I switched to MAF, it read correctly, at least much more correctly than before.
1 - 13 of 13 Posts
