Background: bought car from curbstoner who'd bought it at auction and it came with original owner's pink from 1995 and had year's back DMV, so I figure it sat for at least a year (in mild San Jose, CA)
put about 3500 miles since then and now brakes are going soft but come back up with one pump. Brake fluid in Master looks rather dark amber!
Is that a Saab thing?
I didn't notice any wetspots when I got new tires but brakes were acting up at the time either.
Weighing sequence (and parts purchases) to solve problem. Need pads all around. I guess I should buy pads AND Slave cylinders so if when I'm doing pads I notice any leaks I'll have the cylinders, and if I don't notice any leaks at the wheels that means it MUST be the Master going bad???
Any diffs in symptoms between if its Master VS Slave cylinder going bad?
Will Master go bad without showing any leaks? Do Slaves always leak when going bad?
Any weird Saab stuff I should know regarding the brake system? (I've done cylinders and system bleeding before but its been a while)
