I have a tuned 9-5 it is highly modified to about 350bhp with Nordic software.
Recently I have had a problem.
Please note that there have been no hardware or software changes for over a year and suddenly I have a huge misfire under full throttle conditions.
I don't think its the software because the car was ok for 12 months, but now has a problem.
Under heavy load I get a huge misfire, Tech 2 codes 0300 and 1300 with the misfire across all cylinders.
We suspected the car was running lean under full throttle possibly caused by a weakening fuel pump.
At base boost it does not happen.
I haven't been able to get the A/F read yet ;oops:
All this points I guess to an air leak, but one that only appears under heavy load (full throttle), i.e. full boost, the rest of the time she is fine.
BUT....we (Wessy, Karl and I) cannot find any obvious leaks, all vac pipes look fine, all joints seem fine, the EVAP system is fine, the cobra pipe is properly fixed to the turbo etc.
So next I guess we have to start pressure testing things like the Abbott inter-cooler - unless you guys have any better ideas??
One idea though - the car runs a TD04HL-18T turbocharger - Could the waste gate actuator be the problem? (its a standard TD-04 one that came with the turbo some 18 months old now)
I could buy the Forge Waste gate Actuator if you think that this might be the problem.
http://www.partsforsaabs.com/product_info.php?products_id=2604
I'd appreciate any feedback, help or guidance.
Thanks Chris
- An up rated fuel pump (walbro 255) was fitted, as was a new fuel filter, but still the massive misfire under very heavy load.
- We changed the 3.5 bar FPR but no improvement, and the misfire is across all cylinders according to Tech 2 so its not an injector.
- We put in new spark plugs and a new DI, plus the MAF was changed, but still the same problem.
- We have also changed the forge dump valve and the boost control valve just in case.
Thanks Chris
