1 - 7 of 7 Posts
What is the best way to unbolt the rubber connector at the firewall? One side is right against power steeeing lines. The other appears to be welded on nuts. This thing is rusted heavily and I have no detail diagram of how it is assembled. Any insight here? Thanks.
You may be able to pull some useful info from these two images. They are from the Haynes service manual - sorry for the sucky quality, IDK what happened.
268975
268976
Unfortunately, I know essentially nothing about the procedure. So that's all the help I can offer.
Thanks. I have that manual but it is often not the same as the car since it's a non-turbo and stuff is scattered between chapters so I must have missed that pic. I think I'm going to try putting the gear in R and see if there's enough clearance to get it from the wheel well, provided that's not a welded nut. If my camera is back in action next weekend I'll try to video it.
I'll look at Alldata again. But when I checked yesterday, it didn't seem that they were offering much detail.
No, there's not much extra on Alldata. I'm going to dig around for exploded parts diagrams and inventory pictures. I'll post what I can find for reference. The details on this car are limited and often the wiring is only correct for post-1994 turbo models.
Discussion Starter #6
So apparently 4th will put it in position to be removed based on access from the fender well area. We'll see it goes.
Yup, 4th gave access from the fender well. I spent several hours fighting with rusted hardware today. Got 2 trans bolts out and had to pack up due to storms.
1 - 7 of 7 Posts
