Here's the cleaned up gearbox ready for its new home - my 1990 Turbo S Convertible.
Motor vehicle Automotive tire Automotive design Gas Engineering
Automotive fuel system Automotive tire Motor vehicle Automotive design Automotive exterior
Do not make the common heartbreaking mistake!
The engine oil pickup tube must be swapped also! The tube for the autobox will not pick up engine oil in a manual sump.
Cool, thank you for that.
Further to jims comments , be 100% sure that the new manual pick up seats correctly in the O ring to the block , I missed that detail once ( the bracket for the pick up had a very slight bend in it ) as a result it did not seat or seal correctly and the subsequent leak created a failure to prime and all that is associated with that. Nice work on the Box prep , In my opinion this is absolutely the best MOD that can be done to an Auto c900 !
Not too difficult but take ya time , Hopefully you have a donor manual for the bits n pieces .
Also use the shorter flywheel-to-crankshaft bolts, not the longer ones used on automatic flex plate.
