I have a 1999 9-3 convertible. The main beams function only when in reverse gear, either with DRL or "switch position 2"; high beams do not function. No SID message about failure. The bulbs show continuity (both high and main headlamps -- and the mains work but only when manual trans is in reverse!). The high beam indicator does not come on, and the mains stay on (again only in reverse gear) when the high beam lever is toggled. I've tested the two headlamp relays (both function), but not the orange one. All fuses are good, and there's power to left-side of dashboard fuses 15 and 27. Front and read fog lights work. I suspect the orange relay or the DICE, but only because I have no clear way to test them without a tech 2 scantool.
So, the mains working in reverse is wierder than no high beams, but both have me baffled. :roll: Ideas?
