Here is what Ive come across on AMAZON.com...many tend to like this AT-205 leak sealer.
----- will like to have opinions and views of this forum.
ATP AT-205 Re-Seal Stops Leaks, 8 Ounce Bottle (Automotive)[/B]
I have been an automotive technician for over 47 years. I don't believe in "snake oils", but I DO BELIEVE IN AT205!!! I am a Master Certified Tech. I know what works and what doesn't. This product is amazing and may be the most underrated product on the market! I cannot guarantee it will fix every leak, if there is a hole in a gasket or seal, it cannot fix that. This is a seal conditioner. It softens and restores the pliability of the seal to a nearly new condition. One example: A 10 year old high mileage Astro van with a horrible rear main oil seal leak, one of the worst I have ever seen. The bottom of the chassis was coated with oil from the engine to the rear bumper. I don't think there was a dry spot in-between. I have to admit that I had little hope of even helping this vehicle, but it was worth a try. Certainly easier than pulling the transmission to replace the seal, very costly for a high mileage vehicle. We cleaned the bottom of the vehicle. I was totally astounded when, at the next oil change, we found the bottom of the chassis bone dry! It was unbelievable! He had been adding several quarts of oil between changes and afterwards I know it was next to nothing, if anything at all.
I have used AT205 on my own vehicles. To repair most rear main oil seal leaks today requires removal of an engine or transmission. I might have to add this product to 2-3 consecutive oil changes, but it has always substantially reduced or eliminated the leaks all together. 2-3 bottles of AT205 is a lot less expensive and a lot less work than the alternative. If the first bottle does not complete the job at hand, give it 1-2 more tries before giving up. If the seal only needs to be reconditioned, this product will definitely do it. Do your self another favor when doing the job, use only a good quality engine oil like Pennzoil. The additives in these products are worth a few pennies more. There is a lot of hype about different oils and everyone of them has their own claims. I have used Pennzoil exclusively for over 30 years and with doing nothing more than changing oil alone I have had several customers as well as myself reduce oil consumption and lower emissions on some of the higher mileage vehicles. And I never use the "high mileage" oil, just good quality Pennzoil.
thnx
