1 - 2 of 2 Posts
Has anyone lowered there 9-7? I've seen plenty of TB's out there that are lower than our factory job. Looks very nice but I don't want to mess up the ride quality or suspension.
If you have, please list parts and part numbers!
Thanks!
I lowered my 9-7X. It cost about $150 total. There's a guy named Scott on tbssowners.com who makes a set of lowering collars. You remove your front spring/shock assembly, remove the clip holding the spring perch in place, then use his collars (with the extra piece) to support the spring perch. It lowered my 9-7X about an inch and a half over stock. In the rear, I just adjusted the stock airbags. It was all very simple (once I had the right tools). The ride quality is similar to stock (though it doesn't feel quite as good). You will need to align your car when you're done.
Pictures of my 9-7X (before and after) with side by side shots with a Bravada
http://www.cardomain.com/ride/2730007
Front collar instructions/How to
http://www.tbssowners.com/forums/showthread.php?t=1535
Front collar info
http://www.tbssowners.com/forums/showthread.php?t=1044
Front collars on e-bay
http://cgi.ebay.com/ebaymotors/Trai...016QQitemZ260190224580QQrdZ1QQsspagenameZWDVW
Rear air bag instructions
http://www.tbssowners.com/forums/showthread.php?t=34
Good luck! If you need any help, just ask.
Tim
1 - 2 of 2 Posts
